Vinny said:
After reading the article.It seems the 1st problem stemmed from the first builder that shoulda spun the engine to look and observe if there was any clearance issues.
:them: The reason Falicon does not accept responsibility is because
They did not assemble the motor.The company supply's parts only.
Unless you have a product failure, It's up to you to assemble CORRECTLY.
There are clearances on Rod bearings when stroking the crank that,
Falicon is not concerned with as they do not assemble them.
To blame the supplier for assembly problems is not fair IMHO.
Rod bearings fail for one of TWO reasons ONLY.
Lack of oil,and lack of clearance.
There are bearing SIDE clearance's when stroking the motor,
That if you are not familiar with,will spin them.
Most people that spin rod bearings blame the crank.
Cranks do not spin rod bearings.
