Hey, I just thought I'd share...
I removed the inner baffles from my stock pipes today. The first one took about an hour and a half, the second one took about 15 minutes!
On the first pipe, I used a 1 3/4" hole saw to seperate the front and I used a 1 3/4" hole saw to cut the back out.
On the second pipe, I used a 1 3/4" hole saw to seperate the front and I used a 3.0" hole saw to cut the back out.
I used at wooden dowel to keep the hole saw centered and alinged for the exit cuts. Check out the pictuers.
Using the 1 3/4" hole saw to seperate the back of the first pipe was a mistake. I had to use a nibbler (and broke it) and then I had to used some small grinding wheels to enlarge the hole enough to remove the baffle.
On the second pipe, the 3.0" saw was the perfect size. After the cut the baffle slid right out.
The first picture shows the exit of the first pipe cut with a 1 3/4" hole saw.
The second picture shows the 1 3/4" hole saw with a 1 1/4" wooden dowel attached for centering...
The third picture show the exit of the second pipe cut with the 3.0 inch hole saw.
The forth picture shows the 3.0" hole saw with a 1 1/4" wooden dowel attached for centering...
The fifth picture show the nearly finished product. I have to do some clean-up...
The sound is awesome! This is the way the VRod should come stock... I cruised around the local mall and I set off a half dozen car alarms. It was way cool.
I know I'm running lean presently, but monday I'm going to have the "SE slip-fit flash" downloaded... Also, going to get a K&N air filter.
In the mean time I was thinking of adding some octane booster. Anyone have any thoughts on that?
Thanks for all the ideas, suggestions, and feedback out there.
