Hello All,
New to the forum, Been reading a lot, I have a 2004 V Rod (new to me) that seems to have a funky issue in gears.
It has 7k in miles.
If I slow shift into 1 from N it will bounce off the teeth and catch.
1 to 2 it will sometimes go smooth but it seems more often to bounce and then engage. Few times(rare, could be operator error
) it will end in N.
3 to 2 can be stiff but smooth engagement
2 to 1 stiff and rough at times but usually okay
1 to N and 2 to N fine and easy to find.
3-5 feel great up and down.
No clutch slip.
It feels like in one of our ATVs when the cable is too loose and the clutch grabs but I am not sure I can adjust the tension on the Vrod.
Other than clutch grab I suspect the Fork/Drum to be an issue. If so what are we looking at on this motor? Full Case Split, Timing, Cylinder and all or is it accessible?
Debating on doing the repair if major/minor on a weekend or waiting until winter and doing a few upgrades/rebuild then.
Anyways here she is with a fresh wrap, I have to wrap everything
Thanks in Advance,
Don
It has 7k in miles.
No clutch slip.
Thanks in Advance,
Don
