O2 Bung cap size for V&H 2in1 Comp
2.4K views 3 replies 3 participants last post by  RONVROD
#1 ·
Like the title says, I'm looking for the size of the unused O2 sensor ports for my Muscle's 2in1 Comp exhaust. The ones that came with it are rusted and I would like to get some stainless steel ones.
#2 ·
Not sure what you mean by "unused O2 sensor ports" except that I'm assuming the "used O2 sensor ports" are the 12 mm ports for the OEM O2 sensors.
Just to cover all possibilities, there are two size bungs supplied with the late model VRSC V&H exhaust systems:
the OEM O2 sensors fit in the 12 mm diameter x 1.25 mm pitch bungs
the other set are 18 mm diameter x 1.5 mm pitch and are used by standard O2 sensors including the wide band Bosch LSU 4.2 that most dynos use​
