Hey all,
I was riding home the other day, went to use my rear brake and it went all the way down with 0 pressure or stopping.
Got home, found brake fluid dripping off the frame. Got my scope out and found the fluid was coming from a sensor on the rear brake line. I checked the fitting, and it's tight, pretty sure the fluid is coming from the sensor.
Does anyone know what this senor is called? Is there a way to fix it without replacing it?
I didn't mess with the sensor, wanted to know more about it first.
Thank you!
Thank you!
