I think I might have come up with an idea and a way to manufacture additional fuel cell space for our V-Rods.
There is space behind the rear shock absorber on each side to manufacture from aluminum fuel cells that could add about another 70 to 100 miles range.
These would be like something that would like like a bubble skirt off a car made in the 50's. Flat in design from top to bottom, but curvatured enough to follow the rear fender lines, and flat or straight to foolowe the shock lines. The rearmost would be a straight run up from the bottom to meet the rear most top curvature of the cell.
If the components were made from aluminum, they could be finished in satin or polished aluminum for looks, but, the thing is, the design could incorporate saddle bags that could be tied in over the side of the cell themselves.
The cells would be about 3 " deep, 15" in a slight curvature design at the top, and cut at the bottom to allow clearance of the caliper on the right, and belt on the left. The bottom of the cell would be anywhere from 7" to 9" in length, just above the rear axle, and more in line with the bottom of the shock absorber.
Connections for the cells could be made out of quick disconnect lines, once done with your trip, simply remove the cells and saddlebags from its mount on the shcok absorber, and also a possible saddle mount that runs under the passenger pillion.
Front mounting would be incorporated through the shock system, as the top spacer gives enough space to accomodate tie in, bottom would have a double loop over the bottom fastener and knuckle of the shock.
These openings of course would have to be isolated with rubber or silicone that would aid in reduction of vibration, more so when the cell runs dry.
The backs of the cells could be reinforced with flat aluminum stock, heavy enough to reinforce th ewhole system, but light enough to allow the bike to handle well. This would be in part due to the center of weight being near the rear axle, and not extended too far back from the rear axle central axis.
From measurements, it looks like that it would be quite possible to pick up 2 to 2.5 gallons added capacity, maybe more, maybe less.
Is there a market for something of this nature, and if so, what would folks think would be a reasonable price for a set up that just may come off looking good?
Anyone have access to do a cad drawing of this for further evaluation?
