Hi. I have an 05 VRSCB and the clutch is slipping. We opened and found the resevoir was pretty contaminated. We used clean DOT5 fluid to fill and again bled the air out. After a short test drive I felt the same slippage going on. I installed a Power Commander about 2000 miles ago.
Questions please.
Did the clutch possibly wear beacuse of the extra horsepower and torque of the power commander?
Is the Clutch replacement expensive?
Any advice please... Thanks!!
Unlikely that a PC would provide any significant horsepower increase and regardless, all VRSC engines (even the restricted HDI versions) are capable of burning up a clutch if miss-used.
A slipping clutch is not caused by air in the hydraulic lines. The symptom of a hydraulic clutch that needs bleeding is difficulty going from neutral to first (the clutch won't release).
A slipping clutch means either too much fluid in the reservoir (the slave piston can’t move back and allow the plates to engage) or worn/damaged plates. If the plates are worn or damaged the only solution is replacing them. If the bike has been abused by riding the clutch, not fully releasing when applying high torque, or running with too much fluid in the reservoir, the plates could be damaged and may need to be replaced. It would be hard to diagnose without looking at them (there will be signs of excessive heat on the steel plates). Another way the clutch can be damaged is using the wrong engine oil. Some motor oils have friction reducing additives that will make the clutch slip. Once it’s soaked into the friction plates it's virtually impossible to remove.
BTW, a new clutch (37938-08KA) is relatively inexpensive (US MSRP is $240) and easy to replace (
see this thread).
