Backfiring with TABS installed and PC-V
3K views 11 replies 6 participants last post by  swtalbot
#1 ·
Hello Team:
Is the backfire normal under deceleration? What causes the popping/backfire? Before installing the TABS slip-on's (non-baffled) there was no "popping" from the stock exhaust.
I'm using PCV map: 15-006-014 - TAB Performance slip-ons (turnouts without baffles), Stock air filter, Stock ECM because that's my exact configuration.
Changing the air filter or removing the top cover will eliminate the popping?
Thanks
#2 ·
it's your map on your pcv. need to find a more well tuned map, and possibly the auto tuner might fix it as well. i dont know exactly how well the auto tune for the pcv works, but that's a place to start.
#4 ·
I may be wrong on this, but I believe that it would be running too rich if its backfiring. The extra fuel pumped into the cylinders makes its way into the exhaust pipe and explodes..
#7 ·
Update
Hello Team:
Went for a long ride (200+ miles), remove the top cover for the air filter but still popping when I roll off the gas. Put the top back and still the same.
Today I used a map sent by fuelmoto. I think the bike felt more responsive with the first map from Dyno jet (15-006-014) but the popping was the same. Is not as loud as backfiring, is just the popping sound on deceleration.
Thanks for all the advice.
#11 ·
Update
Team:
Kudos to EOD J ROD, after making the changes he suggested, no more popping on decel. the TAB slip-ons even sound different, perhaps is my imagination? Anyway EOD J ROD nail the problem. I made the changes on the Dyno jet map: 15-006-014.
:notworth:
I'm becoming a premium member of this site. I have learn some much about my new bike! :cheers:
Thank you very much for all the advice!
#12 ·
Like the thread subscribing for updates.
:thumb:
