Arnott Air Compressor
1 reading
4.3K views 13 replies 6 participants last post by  kwikcoupe
#1 ·
Well, I have the Arnott's on the rear and Frank's Front Fork Slam Kit on the front....
I've decided to go with a second Arnott compressor to work the front independently (sp?) from the rear...
I've talked to Ken and he said that with 5 or more orders, he can get us the compressors for $250 shipped.
This is the kit: http://cgi.ebay.com/ebaymotors/Arno...QcmdZViewItemQQcategoryZ35569QQihZ025QQitemZ380014031266QQrdZ1QQsspagenameZWDVW
Just wondering if there was at least 4 others out there that want another compressor so that we could all take advantage of the discount?
#2 ·
I would be in, but I don't think i can fit another compressor in my airbox.
#3 ·
Just put it where your rear wheel is supposed to go... :stilpoke:
Nobody else wants/needs a second compressor?
#4 ·
Don't need a compressor, but would like to see some pics with Franks slam kit on your bike George. :)
#5 ·
:laugh: Once I get home again...
#7 ·
You could just run more solenoids and not use a second compressor. I have both kits that I am putting on my DX and that is what I intend on doing. You just have to work out the switches to control it. There are several ways of doing it but I am going to run 4 solenoids so that I can raise and lower the front and rear independent of each other.
#9 ·
hmmmmmm...... Just when I thought that I knew what I was going to do..
#10 ·
You do not need a second compressor!!!!Just get the 2 way toggle air valve from Clippard and you are ready to go!! No need for an extra solenoid.Let me go look at mine and see what part # it is.
Not done securing this all down,butthe valve is a TV-2S in the Clippard Minimatic catalog.In the pic you can see were I mounted the valve.Billy(halfnutz67)put his in his horn cover.You can put it anywhere you can reach.It looks like a spagetti mess but its really easy to configure the layout.Just make sure all the fittings are tight and use the liquid thread sealant.Teflon tape sucked!!!
#11 ·
Also ,my relay setup is a lil different because I have a PLatinum air ride with bleed feed system.I use air to lift and lower plus it uses air for rebound!
#12 ·
SlammedRod,
What is the part number for the unit with the 4 solenoids on it? I would be interested in seeing the specs on that.
#13 ·
It came with the Platinum Air Ride kit.I think it's something they make for this setup.I'll look and see if there are any part #'s on it
#14 ·
Sorry to bring back an old long dead thread, A question for Slammed Rod. Can you post how the system air in routed throughout the various pieces please. I am trying to trace then through the air box cover to view but I get sort of lost on some of them. I understand your system in not like others. It also looks as though the compressor is a VIAIR 95C, is that correct? I was looking at the 98C for my setup which is very similar in size with a greater CFM.
If anyone else has adapted this system into a modified design please post the changes. I know this a very old setup. I was thinking a single air source but a second set of solenoids and another set of switches. That's pretty complicated and expensive when your looking at a $20 toggle switch.
