Hi guys I took my bike down to the dealer today to get the abs brake bleed and the computer flashed mind you I didn't have any abs light coming up on the dash only when I first turned the key on like they all do and I was getting this done as I have changed my brake set up and I was having trouble bleeding the rear brakes. So they try and do the flash then they come out and tell me its coming up with abs codes C1216 G3 Output open, C1095 G2 Output open, C1094 Front brake switch stuck, C1214 Rear Brake Switch Always On and now the abs light is always on I have no left indicator but it will work when the alarm arms it self and since I've got home I have no head light and no brake light! any idea's as I'm really pissed now. And I do have LEDs all round and led brake and tail light.
I'm not sure I understand what happened. Are you saying you went to a dealer for a Digital Technician ABS brake bleed and you left with several ABS DTCs still active? If so, why did you leave the dealer before he fixed the ABS problems?
Concerning the DTCs you listed:
C1094 = front brake switch always on and usually means the front brake was applied while the bike was accelerating but could be due to a bad front brake switch or a short to voltage in the front brake circuit.
C1095 = front brake switch open and usually means the front brake switch is disconnected or damaged. It can also be due to a bad diode pack, open tail light circuit, bad rear brake wiring, or a damaged ABS ECU.
C1214 = rear brake switch always on and usually means the rear brake was applied while the bike was accelerating but could be due to a bad rear brake switch or a short to voltage in the rear brake circuit.
C1216 = rear brake switch open and usually means the rear brake switch is disconnected or damaged. It can also be due to a bad diode pack, open tail light circuit, bad rear brake wiring, or a damaged ABS ECU.
None of these DTCs will disable the ABS system or set the ABS light to turn on. You must have other DTCs set that you haven't listed. I would first read and clear all the DTCs (this is a link to
how to read and clear DTCs) and then see which ones return and post them here for additional help.
I'm guessing you have a blown LIGHTS fuse and that's why your headlight and tail light aren't working.
