Well, it seems that the EPA not only has it in for us with regard to pipes and noise, now they want us to wear heatshields for pants.
As some here may know the air cooled crowd has been all up in arms over the increased heat since they went closed loop in '07. I'm here to tell you that the '08 V-Rods now share the same affliction.
I spent about an hour in traffic yesterday and I almost had to stop and get off the heat was so bad from the right side of the motor (pipes). Looking at the exhaust pipes you can see the heat discoloration. All of this is directly attributed to the closed loop 14.6:1 AFR these motors run at low to mid throttle. I have the Race Tuner and will be putting the lower sections back into open loop ASAP.
Here's a good article on the issue and an aftermarket solution. Of course when you get done buying 2 of these you have already paid for the Race Tuner.......
If any other '08 owners have experienced the heat conditions post it up, lets see if we can get H-D to remap these for cooler operation at low throttle (traffic) so none of us have to buy anything. They did it for the TC's it's time they did it for Revo's.
