1 - 7 of 7 Posts
I know there are a lot of post on coolant leaks, but I didn't find one that offers info on my problem......
I topped up the coolant to the full, I bled the line removing air using the bleeder valvle in the air box.......
I did all this in the fall (oct) when I put the bike away for the winter.
The bike has not moved since Oct, and I have puddle of coolant under my bike........WTF...... Is it possible that there is still air in the line?
Any info, greatly appreciated
Killer Service Inc.
Did you over fill it?
I have seen this happen.
I filled the over flo bottle to the full line, then did the bleeder thing
Have you run the bike to check for leaks? Is it a wet puddle (fresh) or gummy? Too many things could have happened, over filled, spilled the coolant, cracked nipple on your overflow, leaking clamp.... Start it up, get it to operating temp and check for leaks. Start at the highest point possible and work your way down. If you dont do the dye/light mehod, try using a clean paper towel and run it over all of coolant system until you find leak. They can very tough to find, I hope you dont have a pinhole in your radiator like I did, it is a PITA to work on....
durata membro
You have to fill the system at the filler cap under the air box.The plastic tank is just for recovery for when the cap blows off pressure.The recovery tank is not where you check the systems coolant level.The cold fill line is so that when the pressure releases from the filler cap,it doesn't spill on the earth.These recovery tanks save big motorcycle and auto companys a $5 fine per unit.
These motorcycles will leak coolant sitting still almost the same as any automobile engine will,more on the Revo's cooling system because of the worm drive clamps.Most auto's have spring clamps that will keep a constant pressure on the hose as the rubber wears and sets in.The Revo needs a nut driver on the clamp to take up the slop.
Discussion Starter #6
great info
i shall look for the leak once i put my battery back in
thanks again guys
Hoses shrink and allow the hose clamps to loosen. Deep cold worsens this. We always had "cold coolant leaks" on heavy trucks in the winter when I was a driver. I little elbow grease with a screwdriver usually solves the problem.
1 - 7 of 7 Posts
