1 - 7 of 7 Posts
Pretty sure I saw one on Ebay yesterday.
Friend of Max.
gbflex said:
The entire clutch, plates and springs.
Clutch plates and STEELS. Your springs should be okay. You can check them with the Micrometer when you pull them out.
I have a used clutch. The plates look good, 2 steels have mild bluing. You can use it, if you have 2 steels that are salvageable from your current setup. We can check overall pack height to make sure it's in spec.
You know my number, just let me know if you want to give it a go.
RJ
RJ
Bosch Tools and clutch work, sounds like to plan!
1 - 7 of 7 Posts
