1 - 7 of 7 Posts
"Vrod King"
You can purchase new fans from spalusa.com. They are around $70 each last time I checked.
Mike_W,
Could you be more specific as to which fan is the right one? That web site sells a lot of different fans.
"Vrod King"
Mike_W,
The VRSC fans used by HD are Spal "pull" type. For the early models (2002 & 2003) the fans used where Spal P/N VA31-A101-46 A. In 2004 HD changed these to a special dual fan unit = Spal P/N 2VA58-A101-46A. This dual unit is only available to HD.
The fan diameter for both versions is 130 mm = 5.118".
Thanks Mike.
I have a set. I ordered a new set, and they were on back order so ordered a used set. its both fans and I do believe all years are interchangeable. If your interested please hit me up.
I was going out of town so I just ordered 2 used off fleabay.... fingers crossed they work.
1 - 7 of 7 Posts
