I have a CVO seat and it is starting to get some wrinkles on the seating surface. Here is a picture of what it looks like. Does anyone know how to get rid of these? Thanks
Dampen it, and use a blow dryer to shrink it back. Joe
Hey Joe-Thanks for your comments. I really don't want to mess the seat up. So, I am going to ask more questions. Are you just using water? Do you wet it pretty good or just lightly? Have you performed this with success in the past? Thanks again, I really appreciate your input.
Don't soak it with water. Just get the surface wet as if you where washing the bike and then let it set in direct sun light for a few hours.The vinyl material should tighten up.
The blow dryer method will work but I've seen people get the vinyl material too hot and actually burn / melt it.
You should also check that none of the staples on the back side have come loose or pulled through the material. This is a simple fix.
