Check your battery. If the battery is weak, it may have just enough charge / cranking amps for the starter but not enough to power the ECM, fuel pump, etc. If it starts with a boost, then let it charge up your battery to see if it can accept a full charge. Parasitic loads like security will drain down the battery, which is why you should always use a tenderer.
