1 - 3 of 3 Posts
I have developed a front end wobble from 30 to 35 mph only seems to wobble between that speed range unless I hit like 110 but then it works itself out to any ideas?
Assuming you've checked the axle bolt & brake caliper bolts, the next thing is to look for a missing wheel weight. Using dyna beads will solve the balance problem & during the process of removing & replacing the wheel, the wobble should disappear. Look closely at the tire for a bulge that may be a broken cord. let us know what you found.
SUPERBRACE - but that's good for the 110MPH wobble. Low speed is tire, wheel, balance or alignment (forks/axle or front to rear)...
Rick
1 - 3 of 3 Posts
