1 - 10 of 10 Posts
Installed a Heavycycle tail light and Kuryakyn led turn signal mirrors, turn signals start out slow, but get faster, do I need to install a load equalizer?
Part #4810 came with the signals but I am ont sure where to intall it.
I have done all this without cutting into my main wiring harness, and would to keep it that way. Is there anything wrong with a faster blink rate? This is on an 05a. Thanks.
Friend of Max.
The TSSM will blink normal for 4 cycles, then start the fast rate. It reads the low draw of the LED's as an "OPEN" circuit. It thinks a bulb is burned out.
You can install a load equilizer, I reccommend the unit from BikeTronics Smart Equilizer. It jumps between the connectors for the front signals and requires no splicing.
You can get it from Heavycycles.
electrical help
Thanks for the info, I am not real keen on the electical portion of these bikes, will this slow the front signals also? or do I still need something up there? Thanks again.
electrical
From the looks of my first post it appears I am not real keen on spelling either.
Friend of Max.
No. One is all you need in the system. (SmartEquilizer that is)
I put the Kuryakyn equalizer by the TSSM, under the pillon seat, 4 years ago. No issues since.
load eq is what you need. search the net you will see one from nevada. i forgot the name. installed them and no problems.
I'll Take Two Please
Just an FYI. I purchased the Biketronics version load equalizer and had to rewire it. After hours of head scratching and a 12 pack. Factory (Biketronics) wire harness was wrong. May have been an isolated incident, but it wouldn't hurt to check it. I just pulled the wires and relocated them correctly in the plug.
load equalizer
Thanks for all the input, the equalizer from Biketronics is the one I had decided to go with, good to learn they can be wired wrong from the people that manufacture them. I am with you on the cold ones, who was counting for you?
That U in my mirror?
daleboy - I have pictures in my gallery on where the Biketronics connects.
1 - 10 of 10 Posts
