Call them and see what they can do for you. I would be very curious about their pulley choices and method of mounting. Keep in mind you will want to change the pulley sizes to keep the overall gearing the same if you switch to a smaller 17 inch rear wheel, and this has implications for belt length. Working that out and finding a belt the correct length was one of the hardest parts of my XR wheel conversion. Keep us posted on your progress.There are many custom and reasonable wheel options when it comes to wire wheels
Even Aluminum...Check out these
http://www.hdwheels.com/Product.htm
My Thoughts are will be easier than the Buell Wheel Mod or the one you did with the XR1200 ??
Haven't done it yet so was looking for some input...
From looking at the web site, it looks like this will be a simple bolt-on installation with the proper hubs ordered. Not sure about you being able to get hubs for the stock R front brake rotors with their wide bolt pattern. That's a simple fix though by using rotors from another Harley model that uses Brembo calipers.There are many custom and reasonable wheel options when it comes to wire wheels
The front rotors are not a problem. You can use the rotors from the VRSCAW/VRSCX. I use these with my XR-1200 wheels front and rear. What I would be very curious about is their choices for pulleys and belts. If you keep the stock pulleys you will lower the gearing noticeably due to the smaller diameter rear tire. Keep us posted, it's interesting.From looking at the web site, it looks like this will be a simple bolt-on installation with the proper hubs ordered. Not sure about you being able to get hubs for the stock R front brake rotors with their wide bolt pattern. That's a simple fix though by using rotors from another Harley model that uses Brembo calipers.
Call PM and ask. They are a great bunch. I used to live a few blocks from their factory, they have a really cool little motorcycle museum. Their tech people have all the dimensions for the various wheels and bikes, know what fits what and what doesn't. I'm sure they will sell the adapters. They helped me out with dimensions when I put the XR-1200 wheels on my R.If PM does make the adapters and would sell separately, that could possible open the door for virtually any HD wheel...or at least a good many..?
That bike has the Brake Tech 320 mm rotor conversion kit on it. Now, take those wheels with the brake rotor adapters and isolator bowl from those Performance Machine wheels and you're there. You would want a 30T front pulley at least however, or the gearing will be way too low with that 17 inch rear wheel. I guess you could also use the 70 tooth pulley from a Soft Tail on them with no special adapters, but the pulley would not be rubber isolated. I seem to recall there was a compatible width belt for that pulley from S&S.Another sporty wire job....
