1 - 20 of 23 Posts
Hello all
I recently purchased a windshield for my f and would like to know if somebody makes a deflector that attaches to it because riding with it pushes all the air right to my eyes and makes it hard to keep my glasses on. Any help is greatly appreciated
thanks
2009 VRSCF
This is why when I use mine I always wear my full face helmet.
On the Space Coast
I have made an adjustment to mine to change the angle slightly. I'll take photos and post them later today. It really helps. Just amounts to a little extension to the handle bar mounts to make the shield a little more upright.
Posting From The Pub
I think we need Lux at this point.
I share onpoint's problem but live with it because it blocks wind pressure off my chest. Hope dabusses pictures will bring some relief (to air in the eyes, that is.)
I installed a new HD windshield on my D last Sunday and had the same problem. I found that by ignoring the directions and moving the handlebar clamps as high as possible on the bars I was able to change the angle of the shield enough to eliminate the problem.
Move the fork clamps up as high as possible and loosen the handlebar clamps. The goal is to get the shield to sit up as verticle as possible. I had to loosen the controls to get the shield clamps under the banjo fittings on the fluid reservoirs. After the winshield is as verticle as possible, tighten everything up. Worked great for me.
i have the same problem with mine if i wear an open face. beard blows upwards as well. full face not to bad. touratech make a universal deflector but its a bit pricey and i'm not sure if it fits.
Problem is that mounting points are fixed on the F's handlebar.
You do give an idea though, what about fabbing "shorter" links between windshield and fork tube quick clamps? .....will look into that tonite
Marcelito
Deflector
Try www.laminar.com -have the same issue with my F with mid sport screen -I haven't done this yet but I have a small sport screen add on from laminar for my Speed triple and it works great.
Cheers
Hello all
thanks
Muscle A4 HOG
Link below is to Rifle windshields. I got the 4 inch longer clear screen to stop my wife complaining about getting the wind in her face with the original HD screen. Just used the HD brackets off the original screen. They also do a 2 inch longer which may be enough if your not needing to consider a pillion.
http://www.rifle.com/Motorcycle/Har...cycle=2009-Harley-Davidson-VRSCF_V-Rod-Muscle
thanks for this, i think a +4" smoked will be ordered soon. can i ask how tall you are?
Registered Boozer
I recently installed the HD windshield and love it. Half helmet is much more comfortable now and I can wear any glasses for eye protection due to the reduced direct air.
edit to add: one draw back, the high beams reflect back making them basically unusable.
Jeff
I had the same problem, got the 2" taller smoked windshield from rifle & it put the air on the top of my head Im 6'.
jljakyl, thanks for posting your height and the pic. I'm 6' 5" and know that the HD windshield isn't going to work for me. I'll be eating everything that comes my way with that little shield.
Is it more cost effective to buy the HD F windshield kit (to adapt over to the rifle) or piece part it?
Jeff
My bike came with the hd windshield so all i had to buy was the rifle fairing. not sure how much the windshield kit is from hd. but if your 6'5" your gonna half to go with the 4" taller. i dont know if you can just buy the hardware without the windshiel from hd.
Jeff
Yeah, good call. 4" taller it will have to be. I'll go clear so it won't look completely ridiculous and upset the look of the bike.
Thanks.
Jeff
Need Help for windshield size
Hey you guys, I need help with ordering the windshield size from Rifle. I'm 6'2 and don't know if I should order the 2 inch taller version or be safe and go with the 4 inch windshield. I want the wind to go over my head.
1 - 20 of 23 Posts
