1 - 2 of 2 Posts
Noel
Howdy folks curious if any of you have experienced problems with communication between the race tuner and your laptop after upgrading to Windows 10?
This application was working under windows 7, now I'm having troubles establishing communications to the VCI.
Any help or advice appreciated.
Noel
Discussion Starter #2
I've figured out the issue, it seems the SE Super Tuner PRO shit the bed and might be the root cause of rough running and intermittent stalling of the bike, over the years I kept it connected at all times to use as an in flight data collection tool. Seems that the hardware might be defective.
My solution is to use my TTS Master Tune with the blue VCI box, it is communicating with the bike and laptop, I'm able to read the ECM, make a back up copy of the active map and will be able to send MAP updates as needed.
Hope this helps others in the future
1 - 2 of 2 Posts
