Trying to figure out if this would work when adding mids to forward control braked bikes.
The brake system is a closed system. Any pressure exerted on the pedal forces fluid though the lines and moves the caliper pistons. Is it possible to add an ABS line from the mid control in conjuction with the already existing front control line ? This could be accomplished by using a double banjo bolt in place of the single one on the front caliper master cylinder. Pressure exerted on the mid control forces fluid through the double banjo bolts and up toward the ABS module. After that system acts as designed. See the diagram attached. Simple drawing just trying to illustrate the idea. Thoughts?
