1 - 10 of 10 Posts
Registered Used
Hi
Anyone else have this problem?
Sometimes - usually when its dark and I have a girl on the back - embarasing, the blue headlight on the instrument cluster stays on but my headlight stays off. If I sit there for 2 or 3 minutes it will come on.
Any ideas?
Cheers
The blue indicator is high beams - what happens if you switch to low beams? Same thing?
Sanctimonious
used to happen to me when I turned Left, found the wire to the bulb frayed.
Registered Used
Discussion Starter #4
Even if I switch from low beam to high beam and back the headlight still stays off and the high beam indicator stays on. Wierd.
The blue light being on all the time is a indicator you have a problem. You probably have a loose connection somewhere. Check the back of the headlight. One or two bulbs/connections depending on the bike. Check fuses, light bulbs, wiring for loose/broken connections.
WHATEVER
you have a short in the left handle controls, trace the wires back to where they conect in the left side cover and you will find it!
Friend of Max.
:stupid:
That's the only way you can have the malfunction described.
1130cc Ninja
definitely sounds like a short.. start tracing wires and look very closely for some cuts on your wiring
Registered Used
Discussion Starter #9
Hey thanks for all the help guys.
Better start tracing then.
Might even drop the handlebars back a few inches at the same time.
Cheers
1 - 10 of 10 Posts
