1 - 18 of 18 Posts
Is it OK to run baffled slip ons (like the TAB) and not run a tuner?
Just wondering, I cant see how it can effect it that much that it would hurt anything...
Thanks...Kevin
Discussion Starter #2
I did some searching, here and across the internet, I still can't find an answer...
Fah q 2
a little more gas in her wont hurt
www.badpenny.org
Thanks...Kevin
Is that all you've changed - you've not taken the airbox top off or changed to a K&N as well have you?
If so you really need a tuner , if all you've done is changed the mufflers then you should [1] be ok although it might be a bit pointless as you won't gain any benefit without tuning it (except more noise of course , which might be your desired effect)......
Steve
[1] - of course your bike may explode tomorrow , in which case I bear no responsibility.If it was me i'd fork out a few bucks to look after my $10,000 bike.....
I ran Tab baffled slip ons for a very short time before adding the tuner, and there was a noticable decrease in perfromance over stock. It did not run well at all and is not something I am willing to do for any length of time again.
You should run a tuner. There was one in the classifieds on the forum for a really good price. Not worth the chance when a tuner is only a couple of hundred bucks compared to a very expensive bike.
Discussion Starter #7
well...OK. I'll get a tuner (Damn it). :broke:
I am.
Running Supertrapp FatShots slip ons.
Their instructions say if you only use 8 of the disks (12 are supplied), then don't have to tune if everything else is stock.
Donno bout TABs.
I am. TAB turnouts, topless (K&N) and when I took it for the dyno run the fuel air was perfect with no mods. No tuner. 110 at the rear wheel. Runs perfect.
Phatass
Discussion Starter #10
Phatass
Hmmm. With or without baffles in your turnouts??
F*@kTard
Buy your tuner carefully, depending on how radical you plan to go with your bike in the future, it might be worth it to get a more expensive and advanced tuner if you plan on radical mods down the road.
Bought a 2010 in the fall with 700 mi on it. Previous guy had Tab baffled turn-outs installed by dealer. I've put about 1200 miles on the bike, about 1000 with the Tabs, and about 200 with some used stock cans I bought off these boards.
Stock cans sound like a sewing machine, but the bike runs much smoother. No decel pops and consistent pull through the rpm range. With the Tabs, the sound is good (perhaps a bit too loud for my tastes), but the bike definitely doesn't run as smoothly. It's not a huge difference, but to me it feels like the difference between a new engine and a 4-5 year old engine with 20-30k miles on it.
This is in virginia/DC area, Oct/Nov timeframe, to give you an idea of temps, humidity, etc.
I plan on buying a tuner in the spring once I start riding again. I'm hoping the tuner will be a step above the stock cans, so it's a double improvement for me.
I bought my bike with the stock exhaust punched out and even with that the bike ran like a pig during open throttle. Definitely noticeable that it lost a lot of it's get up and go.
Light throttle riding was unaffected though.
Yes..V&Hs ,it was the first thing i did.theres no problem with just doin that but ull probably do more later on so keep that in mind.V-RODS dont run at there best from factory so IF u want a tunner its ur call$..Like a young boy with a honda,the louder ur car the faster it goes- LOL yes i have a civic witha big muffler ( found it on side of road- free) only put it on because my stock one broke off.its annoying-wifes hates it, but the 37mpg is great for a work car
Discussion Starter #15
Turns out Reinhardt (sp?) Is about 10 miles up the road, and they are wanting to use my bike to make some slip-ons. If they do, then I will get exhaust for free... He is coming tomorrow to look at the bike and take a few measurements.
Keeping my fingers crossed... That will save me enough bucks to just get the tuner..
Good for you ! Doesnt get any better then that..2 into 1 seems to make the best power and lightens up exhaust weight,but theres nothing wrong with 2 slip-ons
F*@kTard
Dammit, why didn't I know that about 5 years ago!!!!
1 - 18 of 18 Posts
