well seems my OEM rotors are shagged after 14k ! ! ! (2008 DX with brembo's)
there on the wear limit and have slight run out
so what rotors do i go for i know nothing abouts brakes nor ever fitted rotors ????
i dont want to spend massive money , but at the same time want to fit a good set
what rotors do you run and what would you recommend ?
i love the look of the swan comp rotors but wow there mega money !!!!!!!!!!!!!!!!!!
I replaced the front OEM rotors with these: Link
They really work well and don't produce noise or vibration like the stockies. See them installed if you click on my 'images'. I went with the Lyndall gold plus pads instead of the EBCs.
I also put EBC rotor on my 06 street rod with EBC sintered pads. Pads run cleaner and once bedded in seem to work pretty good, only time will tell if grabbing issue returns as I recall it started @6K on factory rotors. I disassembled calipers flushed system and used DOT 5 as well.
thanks guys ! will bear this in mind in another 14k , as managed to get dealer to fit for free as i complained they were only just out of warranty.
