Okay… the PC3 is on the way!! I have the v-modded stock exhaust, SE air filter installed, stage 1 ecm flash and going topless. I have asked a couple of you directly what map you run with the same mods. I realize in order to get everything you can from the engine you need to do dyno runs and adjust to get the best numbers… however I want to get a good starting point. It appears some of you are running the M809–020 with these mods and others have suggested running the –021 for a good starting point. I am new at this so I am digging for all the information I can find.
From the PC web site it looks like the –021 will work fine without being topless, however I’m going topless. Has anyone changed this map for running topless and would you be willing to share it so I can see how it runs on my bike?
I am open for any and all comments and suggestions.
Thanks in advance,
Howard
Thanks in advance,
Howard
