Thanks!stomper said:Should be right under your front vent cover on the right side of the bike. Just pull the fuse out of the plug...
Here, let me try make you feel better with another question you might be able to answer.... what does topless mean to you?robbwest said:It's the 40A fuse behind the right side cover. Can't miss it.
Oops. Beat me to it. Probably the only question I've known the answer to since I've been here, LOL.
:boobs:Beeek said:Here, let me try make you feel better with another question you might be able to answer.... what does topless mean to you?
I believe that is a nut to secure the passenger seat. If you look at the bottom of the passenger seat there is a key slot looking cutout at the rear. That slot fits over the head of your missing screw and then is locked by sliding the seat to the rear. I do have some pictures I took when I installed my alarm if the written description does not make sense.trbo2nr said:I only took two nuts off the back 10mm and I think 13mm to mount the alarm.
Since the rear seat moved, a bolt/screw was on the garage floor and I don't know where it came from! I didn't take anything else apart and sure it goes
some place. The problem is, I don't have good pictures of it. See below.
