Where are you guys installing your fuelers?
I found a nice location right in front of the battery (if you remove one of the small side covers).
i put mine under the battery strap for now not sur i ll leave it there but for now it s all good.probably will go topless and then put it ride beside the air filter.
Retired Devil Dog
Put it anywhere it fits. You should not need to tweak it if you put it on the correct setting for your bike. I placed mine on the right front under the airbox next to the battery so I would have access and not need to stow/cut wires. If you plan on doing a dyno run anytime you will need to access the pots........DC
The Anti-Chrome
Don't mean to jack your thread...but I figured I could get the answer here...
What's this I keep hearing about the TAB fueler and warranty issues? Someone keeps saying to use the PCIII??
Right front of inner air box cover between battery and cover tight fit but it isn't going to move around. That is what Todd recommended and it seems to work out well.
