Just did a quick check and I mean quick. Some listed in Ebay that might work. Match the part number.Since HD has them obsolete will a 2015 rad work?If not where can i get one?
thanks
Can't say for sure what's needed to adapt or convert. One thing I'm quite sure of is the later rads use a GM oil line clip in method with O ring, rather then the JSC or tapered AN fittings on the earlier bikes . You might need to swap out the inlet and outlet fittings on the engine case so the new lines will plug in. I'm not sure what year they switched over to the later fittings , so you might already have them.Glad to see you guys are still around.You've both helped me greatly in the past I would appreciate your opinion on the flowing.
My old radiator part #26722-04 and old oil cooler part #26723-04 are both obsolete with no superseding parts to replace them.
Part #26800027 is a new radiator/oil cooler kit and replaces the original F setup.Since my 07 AW shares the same old part numbers as the F #26800027 should fit with at the most slight modification or thats my logic anyway.What do you think?
I want new because v rods are the only bike that I like and mine looks new at 62000 miles and could go 150000 at which point ill get another.Even the Broken rad looks new with no sign of damage at all.
All of us from mid 13 and down are in the same boat Superseded rather then obsoleted. New rad and cooler new part numbers . It is however a direct bolt on. Just pisses me off you need to buy both. 2014 and up should all have the latest versions. Don't know for a fact but hear the rad has a few more cooling tubes in the core.Looking at the parts fiche at Ronnies Harley the 2016 Night Rod and 2013 Muscle share the exact same parts as my 07AW in the parts fiche including the oil lines and quick connects The only difference i see is the radiator and cooler.My concern is that the parts fiche might be wrong and that HD does not list the radiator and cooler for the 07.Dont laugh but i also found a picture of both the old radiator and the new radiator side by side and measured all the dimensions off the screen.The only thing i can think of is that the new rad does not fit the old cooler and visa versa.I would buy and replace both anyway.Thinking i might pull the trigger and but them along with new coolant hoses and oil lines.Anything else you guys think i should get for the install?
