Thanks guys...just found the point I need a couple of minutes ago.
I really wanted a hot spot when the ignition switch is in "Accessory" as well as Ignition.
Anyway, on the VRod's headlamp plug (the one BEFORE it "Y's" out to the two separate beams) there are four wires. Only three of them are used (Black, Yellow, and White). The fourth wire is Orange with a white stripe. It is not used and is hot in Accessory and Ignition...so I'm going for that.
I like the access a fuse thing, but like I said, I was really after the Accessory position on the ignition switch.
I'm doing a Road Rod conversion, so I have to alter the headlamp wires a bit anyway.
Thanks!
