I have a 2009 night rod special. I am trying to hook up a trickle charger and for the life of me I can not find the battery poles... I know, I know, stupid question, but can someone quickly point out where I might find them?? Thanks.
remove the airbox tin, at the steering stem you will see your battery.
Most of us chose to install a battery tender lead (if your dealer did not install prior to you taking delivery), and just use a battery tender
AIM Bagger Edition
There should be a pig tail for your charger by the radiator... Battery itself is under the airbox...
There'll only be a pigtail if the dealer had the presence of mind to install one during the PDI. Not all dealerships do.
If the bike doesn't have a pigtail, I know for certain that purchasing a Battery Tender Jr. will have a pigtail / quick connect included in the package with the tender.
If you already have a tender and plan on just using alligator clips take the airbox cover off and the battery is at the front. The positive terminal should have a pliable red cover on it that you can pull back to allow you to connect your alligator clips to.
Post up if you need any assistance.
Ya joking, right?
