1 - 7 of 7 Posts
WHATEVER
14 U1255 Current Missing response-at TSSM 4.32 DTC U1064, U1255
No engine light, bike runs great, just changed spark plugs any thoughts?
Scott Whitney
Thats sounds like the ECM may have a problem communicating with the TSSM. That could be a bad connection at the TSSM or ECM, or maybe a battery voltage problem. Clear the code and see if it comes back right away. That will tell you if it was just a glitch, or a still existing problem.
Did you clear the code to see if it comes back? Reseat the connectors.
WHATEVER
I retraced my steps and the code still comes up with the twinscan II there is no other issues and bike runs friggin strong, what els should I be looking for as it is an Instrument Module code?
WHATEVER
OK, I used the Instrument Module to clear the code vice the TSII and it cleared so I think the Twin Scan just would not clear the code or maybe you cant use it to clear IM codes!
1 - 7 of 7 Posts
