1 - 3 of 3 Posts
can i run my 07aw with v&h 2 into 1 pipe and k&n filter for a couple days till i get a map for pcIII or sert. it ran pretty good down the street and back without ecm help
SNAFU
Replace the K&N with the stock filter and you should be fine as long as you don't get on it too much. The motor is an air pump so if you restrict the intake you essentially nullify the pipe.
1 - 3 of 3 Posts
