1 - 20 of 28 Posts
Is one better than the other? Is powder coating a more complex process like chroming or is it done with a spary like paint is done. I see a lot of stuff for sale here that is powder coated but just don't know the difference between powder coating and painting.
1130cc.comaholic
powder coating is a powder that is sprayed on and sticks with an electric charge and then put in an oven to bake it on. It is more durable, but it's hard to get a shine like you can with paint. many frames of bikes and cars are powdercoated so it's more durable and won't chip as easy as paint.
Sanctimonious
What kind of Answer is that?
Powder coating is a type of dry coating, which is applied as a free-flowing, dry powder. The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin." The powder may be a thermoplastic or a thermoset polymer. It is usually used to create a hard finish that is tougher than conventional paint. Powder coating is mainly used for coating of metals, such as "white goods", aluminium extrusions, and automobile and motorcycle parts. Newer technologies allow other materials, such as MDF (medium-density fibreboard), to be powder coated using different methods.
Advantages and disadvantages of powder coating
There are several advantages of powder coating over conventional liquid coatings:
1. Powder coatings emit zero or near zero volatile organic compounds (VOC).
2. Powder coatings can produce much thicker coatings than conventional liquid coatings without running or sagging.
3. Powder coating overspray can be recycled and thus it is possible to achieve nearly 100% use of the coating.
4. Powder coating production lines produce less hazardous waste than conventional liquid coatings.
5. Capital equipment and operating costs for a powder line are generally less than for conventional liquid lines.
6. Powder coated items generally have fewer appearance differences between horizontally coated surfaces and vertically coated surfaces than liquid coated items.
7. A wide range of specialty effects is easily accomplished which would be impossible to achieve with other coating processes.
While powder coatings have many advantages over other coating processes, there are limitations to the technology. While it is relatively easy to apply thick coatings which have smooth, texture-free surfaces, it is not as easy to apply smooth thin films. As the film thickness is reduced, the film becomes more and more orange peeled in texture due to the particle size and TG (glass transition temperature) of the powder.
For optimum material handling and ease of application, most powder coatings have a particle size in the range of 30 to 50 μm and a TG > 40° C. For such powder coatings, film build-ups of greater than 50 μm may be required to obtain an acceptably smooth film. The surface texture which is considered desirable or acceptable depends on the end product. Many manufacturers actually prefer to have a certain degree of orange peel since it helps to hide metal defects that have occurred during manufacture, and the resulting coating is less prone to show fingerprints.
There are very specialized operations where powder coatings of less than 30 micrometres or with a TG < 40° C are used in order to produce smooth thin films. One variation of the dry powder coating process, the Powder Slurry process, combines the advantages of powder coatings and liquid coatings by dispersing very fine powders of 1–5 micon particle size into water, which then allows very smooth, low film thickness coatings to be produced.
Powder coatings have a major advantage in that the overspray can be recycled. However, if multiple colors are being sprayed in a single spray booth, this may limit the ability to recycle the overspray.
[edit] Types of powder coatings
There are two main categories of powder coatings: thermosets and thermoplastics. The thermosetting variety incorporates a crosslinker into the formulation. When the powder is baked, it reacts with other chemical groups in the powder polymer and increases the molecular weight and improves the performance properties. The thermoplastic variety does not undergo any additional reactions during the baking process, but rather only flows out into the final coating.
The most common polymers used are polyester, polyester-epoxy (known as hybrid), straight epoxy (Fusion bonded epoxy)and acrylics.
Production:
1. The polymer granules are mixed with hardener, pigments and other powder ingredients in a mixer
2. The mixture is heated in an extruder
3. The extruded mixture is rolled flat, cooled and broken into small chips
4. The chips are milled to make a fine powder
[edit] The powder coating process
The powder coating process involves three basic steps:
1. Part preparation or the Pre treatment
2. The powder application
3. Curing
Part Preparation Processes & Equipment
Removal of oil, soil, lubrication greases, metal oxides, welding scales etc. is essential prior to the powder coating process. It can be done by a variety of chemical and mechanical methods. The selection of the method depends on the size and the material of the part to be powder coated, the type of soil to be removed and the performance requirement of the finished product.
Powder Application Processes
The most common way of applying the powder coating to metal objects is to spray the powder using an electrostatic gun, or Corona gun. The gun imparts a negative electric charge on the powder, which is then sprayed towards the object, which is grounded. The object is then heated, and the powder melts into a uniform film, and is then cooled to form a hard coating. It is also common to heat the metal first and spray the powder onto the hot substrate. Preheating can help to achieve a more uniform finish but can also create other problems, such as runs caused by excess powder. See the article "Fusion Bonded Epoxy Coatings"
Another type of gun is called a Tribo gun, which charges the powder by (triboelectric) friction. In this case, the powder picks up a positive charge while rubbing along the wall of a Teflon tube inside the barrel of the gun. These charged powder particles then adhere to the grounded substrate. Using a Tribo gun requires a different formulation of powder than the more common Corona guns. Tribo guns are not subject to some of the problems associated with Corona guns, however, such as back ionization and the Faraday Cage Effect.
Powder can also be applied using specifically adapted electrostatic discs.
Another method of applying powder coating, called the Fluidized Bed method, is by heating the substrate and then dipping it into an aerated, powder-filled bed. The powder sticks and melts to the hot object. Further heating is usually required to finish curing the coating. This method is generally used when the desired thickness of coating is to exceed 300 micrometres. This is how most dishwasher racks are coated.
Electrostatic Fluidized Bed Coating: Electrostatic fluidized bed application uses the same fluidizing technique and the conventional fluidized bed dip process but with much less powder depth in the bed. An electrostatic charging media is placed inside the bed so that the powder material becomes charged as the fluidizing air lifts it up. Charged particles of powder move upward and form a cloud of charged powder above the fluid bed. When a grounded part is passed through the charged cloud the particles will be attracted to its surface. The parts are not preheated as they are for the conventional fluidized bed dip process.
Curing
When a thermoset powder is exposed to elevated temperature, it begins to melt, flows out, and then chemically reacts to form a higher molecular weight polymer in a network-like structure. This cure process, called crosslinking, requires a certain degree of temperature for a certain length of time in order to reach full cure and establish the full film properties for which the material was designed. Normally the powders cure at 200° C (392° F) in 10 mins. The curing schedule could vary according to the manufacturer's specifications
Thank you mister wizard
Jeff/Modistrator
Production:
3. Curing
Curing
They teach all of THAT in Porn school? :D
Rollin' Hills
Production:
3. Curing
Curing
Whull---yeah. WOW !
V's and Z's
wiki wiki wiki
Glory to Hypnotoad!
To quote Perfect Tommy, "Mr. Wizard IS the top scientist in his field!"
Fred
Production:
3. Curing
Curing
Holy crap Lux, I'm thuroughly impressed! You must have stayed in a Holiday Inn Express last night. Whats the cause of Global warming?:notworth:
Bad ride inside
umm yeah
VRF0RUMS ORIGINAL
Ok, so what the heck is powder coating anyway?
1130cc.comaholic
Powder coating is by far the youngest of the surface finishing techniques in common use today. It was first used in Australia about 1967.
Powder coating is the technique of applying dry paint to a part. The final cured coating is the same as a 2-pack wet paint. In normal wet painting such as house paints, the solids are in suspension in a liquid carrier, which must evaporate before the solid paint coating is produced.
In powder coating, the powdered paint may be applied by either of two techniques.
The item is lowered into a fluidised bed of the powder, which may or may not be electrostatically charged, or
The powdered paint is electrostatically charged and sprayed onto the part.
The part is then placed in an oven and the powder particles melt and coalesce to form a continuous film.
There are two main types of powder available to the surface finisher:
Thermoplastic powders that will remelt when heated, and
Thermosetting powders that will not remelt upon reheating. During the curing process (in the oven) a chemical cross-linking reaction is triggered at the curing temperature and it is this chemical reaction which gives the powder coating many of its desirable properties.
Preparation
The basis of any good coating is preparation. The vast majority of powder coating failures can be traced to a lack of a suitable preparation.
The preparation treatment is different for different materials.
In general, for all applications the preparation treatment for aluminium is as follows:
edit: picture didn't work
Oils and greases are removed in weak alkali or neutral detergent solutions and the surface is etched to remove heavy oxides. After rinsing, the aluminium is dipped into a chromate or phosphate solution to form a conversion coating on the aluminium. This film is chemically attached to the aluminium. After rinsing the aluminium is finally rinsed in demineralised water. Some non-chrome, dried in place pretreatment is beginning to come onto the market; currently, these are not recommended for exterior applications.
The conversion coating has two functions:
It presents a surface to the powder which favours adhesion more than the oxides that form very readily on aluminium surfaces, and
It reduces the incidence of under film corrosion, which may occur at holidays in the coating.
The use of demineralised water reduces the presence of chemical salts on the aluminium surface. These salts have been found to cause filiform corrosion in humid conditions.
For steel the preparation for interior applications may be:
Clean
Rinse
Derust
Rinse
Iron Phosphate
Rinse
Acidulated Rinse
For exterior applications:
Clean
Rinse
Etch
Rinse
Grain Refine
Zinc Phosphate
Rinse
Acidulated Rinse
The grain refiner is used after acid cleaning of steel surfaces and before zinc phosphating, otherwise the zinc phosphate coatings produced will be very coarse with low adhesion. The powder coating applied to a coarse phosphate will produce rough coatings (a little like "sandpaper") and possess low adhesion.
For hot dipped galvanized coatings, which have been stored for more than about 4 hours before powder coating, the following process is necessary for exterior applications.
Clean
Rinse
Etch
Rinse
Grain Refiner
Rinse
Zinc Phosphate
Acidulated Rinse
The etch is required to remove the zinc corrosion products which begin to form almost immediately the zinc is removed from the galvanizing kettle. The grain refiner ensures a fine phosphate is produced.
How is it done -- electrostatic spray?
The powder is applied with an electrostatic spray gun to a part that is at earth (or ground) potential.
Before the powder is sent to the gun it is fluidised:
to separate the individual grains of powder and so improve the electrostatic charge that can be applied to the powder and
so that the powder flows more easily to the gun.
Because the powder particles are electrostatically charged, the powder wraps around to the back of the part as it passes by towards the air offtake system. By collecting the powder, which passes by the job, and filtering it, the efficiency of the process can be increased to 95% material usage.
The powder will remain attached to the part as long as some of the electrostatic charge remains on the powder. To obtain the final solid, tough, abrasion resistant coating the powder coated items are placed in an oven and heated to temperatures that range from 160 to 210 degrees C (depending on the powder).
Under the influence of heat a thermosetting powder goes through 4 stages to full cure.
MELT, FLOW, GEL, CURE
The final coating is continuous and will vary from high gloss to flat matt depending on the design of the powder by the supplier.
Powder coating guns
There are at east three types of electrostatic guns in use:
Corona charging guns where electric power is used to generate the electrostatic charge. Corona guns are either internal or external charging.
Tribo charging guns where the electrostatic charge is generated by friction between the powder and the gun barrel.
"Bell" charging guns where the powder is charged by being "flung" from the perimeter of the "bell"
Not all powder is applied using guns. One system makes use of electrostatic tunnels.
How is colour introduced?
Colour is added to powder coatings during the manufacturing process, ie before the powder reaches the powder coater. There is little that can be done to change the colour consistently, once the powder leaves the manufacturing plant.
Why powder coat?
Powder coating produces a high specification coating which is relatively hard, abrasion resistant (depending on the specification) and tough. Thin powder coatings can be bent but this is not recommended for exterior applications.
The choice of colours and finishes is almost limitless, if you have the time and money to have the powder produced by the powder manufacturer.
Powder coatings can be applied over a wide range of thickness. The new Australian Standard, "AS/NZS 4506 - Thermoset powder coatings", will recommend 25 micron minimum for mild interior applications and up to 60 micron minimum for exterior applications. Care must be exercised when quoting minimum thickness because some powder will not give "coverage" below 60 or even 80 micron. "Coverage" is the ability to cover the colour of the metal with the powder. Some of the white colours require about 75 micron to give full "coverage". One of the orange colours must be applied at 80 micron.
Colour matching is quite acceptable batch to batch.
Installations and maintenance
During installations, the powder coating should be protected from damage due to abrasion and materials of construction such as mortar and brick cleaning chemicals.
Once installed, maintaining the initial appearance of a powder coating is a simple matter. The soot and grime which builds up on surfaces from time to time contains moisture and salts which will adversely affect the powder coating and must be removed. Powder coatings should be washed down regularly (at least once each 6 months in less severe applications and more often in marine and industrial environments). The coating should be washed down with soapy water -- use a neutral detergent -- and rinsed off with clean water.
When powder coated items are installed without damage to the powder coating and they are maintained regularly, they should be relatively permanent. The correctly applied coating, although not metallurgically bonded to the metal will not crack, chip or peel as with conventional paint films.
:D
Please don't confuse the issue with facts. LakeDrunks answer is all 90% of us want to know.
A simple link to the web address would have sufficed .... but please note we Aussies thought of it first ....
VRF0RUMS ORIGINAL
Well, isn't that special? :plause:
I still don't get it. Its a powder that gets wet, then shiny then dries? Thats cool man.... Has that technology made it to iowa yet?....See here, "powder coating" is used in mating with the native females.
Jeff/Modistrator
In Iowa, thats called a bag of flour!! :stilpoke:
Shine?, actually powder coating done properly will rival the best lacquer jobs in terms of shine AND durability.
1 - 20 of 28 Posts
