I just completed the V-mod on my 2006 Night Rod this week. Love it.
I first perforated around the exhaust outlet with my drill, then finished the cut with my 2 and 1/8" hole saw. Then I flipped the cans over and tapped the baffle out with a hammer and screw driver.
The second longer can was more difficult to tap out. After cutting the outlet end, I had to hammer with the screw driver on the opposite side much longer until the baffle edge started to fold back inward, and eventually had to drill and cut until it loosened enough for the baffle to slide out.
Once the baffles were removed, I cut even slices in the leftover metal that was around the outlet and then pressed them inward to clean up the look.
Check out the pics for the final result.
Sent from my SM-G960U using Tapatalk
