1 - 12 of 12 Posts
brett
what does the air valve looking thing behind the black cap do,its near the radiator hoses or in between the hose clamps,,,i want to put a chrome cover on it and have no idea what it does,,thanks
I'm Bored
With no picture it's hard to tell what you're talking about but I'm going to guess that you're talking about the fuel pressure test port.
Going out on a limb here, but my guess is you would test fuel pressure
Registered Abuser
If you take it to the stealership and your having fuel issues, they could plug in their proprietary fuel pressure gauge tool and test the pressure of the fuel.
also, if you are going to do any work on the fuel system, you can use the port to depressurize the fuel system. when you're done, you can also use the port to purge fuel back into the system and remove any air.
Registered Abuser
Good point. I have never used it myself.
I'm Bored
Check out my gallery. You can also hard mount a fuel pressure gauge. Not needed on normal mods but for my turbo application it saves me a lot of time when trouble-shooting.
Friend of Max.
You can put a chrome valve stem cover on it. It'll be fine.
I made a small knurled replacement cap for mine polished SS, it is a different diameter, I actually made 2, I gave the other to forum member
1 - 12 of 12 Posts
