1 - 3 of 3 Posts
Hi owners, I have an 09 VRSCAW, 13k's, stock apart from sissy bar backrest & rack, V&H 2:1 and topless air box. Also has SEPST, so I made up a cable to go from Bike to Tuner. Checking Tune & says it's running Stage 2.
So far I've added a float to the ultrasonic fuel level sensor tube & am testing to see if this improves accuracy of the lower tank levels - was dropping fast from 1/2 tank, showing empty with ~5l left in it.
FYI check the "171 Recall" if you have ABS, as mine is on the list & has yet to be done.
1 - 3 of 3 Posts
