I have a 2008 V-ROD and noticed that I didn't have front brakes one day when moving it in the garage.
I opened the front right reservoir and noticed that is was empty. I thought this was odd as I have never seen a leak on the floor. I decided it would be a good idea to just bleed and replace both front and rear.
I bled and filled the front reservoir on the right handle without any issues. I opened the left reservoir which I believe is for the back brakes and tried to flush. I used a Mityvac to bleed the lines. Very little came out when I first opened the valve. I then tried again but pressed on the rear brake pedal to help. A little more came out but that was it. To start, I soaked all the fluid out of the reservoir and filled with new fluid. The little bit I got out from the rear valve didn't lower the fluid line much at all.
Now I have working front brakes and no back brakes.
The pressure stays on the mityvac so I know it isn't sucking air...it is like the line is closed on the front end. Is there another reservoir for the rear brakes?
