1 - 12 of 12 Posts
Ths question probably has been asked and answered but as a new V-Rod owner, I need to know. The skins on my bike are the aluminum non-painted skins. I dig the look but I was wondering how to clean it. Does one use regular wax? Or is there something out there just for the aluminum surface. I'm trying to get a bright gleam. I know I won't get a deep shine like paint but I thought I would ask this rookie question.
Doug
sospolice they are an anodized finished. The best thing to do is just keep them washed with the HD sunwash. The wheels will be your problem. We have tried everything on them and they must be dried and kept dry or they will water spot very badly. You will find several threads about Mothers Billet polish and that seems to be one of the best for the wheels.
Max
Tired of the crap
The anodized aluminum skins of the V-Rod will stay nice looking for an extremely long time with little if any additional care beyond regular washings with Sunwash. I've had decent results by following that up with the H-D quick detailing spray - it seems to make rain water bead up nicely, without leaving a heavy waxy buildup.
About the only downside of the anodized finish is that it is hard, if not impossible, to repair any scratches or other damage you get in it. I'd say if you do end up with a dent or scratch severe enough that it mars the appearance beyond what you'd want to live with, you'd probably be best off having the whole bodykit painted.
As Max pointed out - the stock disc wheels can and WILL get waterspotted if you allow brake dust to sit on them for longer than a week or so. I've had good results removing the waterspots with NEVR-DULL, a wadding metal polish, but others have also reported good results with other products.
After wasing it today, I tried some turtle wax on it. Looked ok but I'm thinking of having the skins clear coated. Anyone out there have any thoughts on that? I know I can get the chrome skins but I don't think I like that. I would lIke to have some depth and shine. I think the clear coat and wax would do that. But what do I know.
Doug
just used the NEW Mothers Billet polish.....HAVE USED....never-dull,the Bom, other crap, and the Mothers has them beat hands down.
I have been looking for the Mothers Billet Polish in my area. Hav'nt seen it yet. I want it for the wheels and swing arm, but on the skins? Say it works ok there? I'm still considering clear coating to get a deep reflection.
Doug
sospolice, I tried many things including using a buffing wheel and polish before chroming my skins. An anodized finish is nothing more then a controlled oxidation of the aluminum. It makes the coating very hard but it also makes it very tough to do anything else with. I'm not sure if paint will stick to it as it is or not. You might ask ozzy from http://www.ozzycustoms.com/ he clear coated a set of polished skins that I had.
Max
SPEED DEMON Shark hide is good for sealing the wheels but it is very hard to apply and make it look good. It does stick to bare aluminum very well though.
Live Free or Die
Anodizing is cheap and easy to repair
Anodizing builds up a very hard oxide layer on aluminum which penetrates about one mil deep and grows about 1 mil high above the original surface. So you get about 2 mils of very hard protection on the aluminum.
This newly oxidized surface, as it swells, develops an open pore structure as it is created. The microscopic structure resembles what you see on a kitchen sponge. Since it has deep pores and an open structure, liquid paints adheres very well -- its like the best primer you could ever ask for. My experience in industry has always been to paint anodized aluminum with a 2 part urethane epoxy paint, and that is only because such a paint passes semi-conductor clean room specifications for longevity. Outdoor paints need much more UV stabilization and corrosion protection, so checking with a knowledgable bike painter would be advisable. The surface tension of some liquid paints may be insufficient to wet into anodizing's surface structure, a custom bike painter would know these kinds of details...
ALTERNATIVE
Any anodizing (ano for short) shop will be able to chemically strip off your old anodize and re-anodize your skins, and can change the color pigments while they are re anodizing. Black is the most common, clear is typically second. The color depth of all the others colors that I've seen is rather pale and weak, and only available if your vendor keeps tanks mixed with that color (military green is common in defence industry towns). Beware of any yellow or gold colors, you my be getting Alodyne (sp?) instead, which is inferior to anodize in performance, but is much simpler to process (many often confuse the two names).
When stripping, they need to remove the full thickness of the existing ano plus a little more. I recommend that you have them return your skins so that you can repair your scratches after they complete the stripping.
Anodizing is done in batches, so if you need to repair a damaged air cover, its important to also do your two fenders, two louvered side panels and the radiator covers. If not, you will end up with different shades of finish. It is impossible to match the repair outcome to the original skin, so you gotta do them all. But the good news is that you will not pay any more to strip and re-ano your entire bike, then if you just had one small part. The going batch fee is about $70 for anodize (I can't remember the stripping fee, I think its less), and a batch is typically defined as many more parts then the 8 skins on your V-Rod.
Another thing that influences the final look is the quality of the "surface finish" of the part. I would only be guessing as to how HD does it, it looks like they finish the skins (just prior to ano) with a Dual Action 180 grit or 240 grit. You could successively sand your way up to 240 by starting with 80 grit coarse, to remove your damage, then step to finer grits till you hit 240 (always sand aluminum wet, I use windex from a squirt bottle). It might even be worthwhile to step to finer polishing grits like Mothers Billet Polish on a buffing wheel, just to see how the final result would look after anodizing. The great thing about anodizing, is that you can keep re-doing it by stripping it off again and again.
Anodizing shops are found locally to all large cities, see your yellow pages under metal finishing.
SUMMARY:
Clear Anodizing is cheap and easy to repair. It is definitely less expensive then painting. You can do it yourself, all you need is a $50 Dual Action orbital sander, a variety of disks, and an Anodizing vendor in your area. Around here we are getting 24 hour turn around's at the anodizers (their business is currently down due to economic times). This is one of those excellent winter projects for those of us who put bikes away for the winter.
If You Ain't Cav...
Doug
Doug,
Mother's Billet Alum Polish DOES NOT work on the skins, only on the wheels, swing-arm, and other Billet Alum parts, not the anodized skins.
Mike
1 - 12 of 12 Posts
