1 - 10 of 10 Posts
drag racer
i would like a wiring diagram for the ecm and the ignition switch for a 2006 nightrod.
Friend of Max.
You need a service manual. The digrams are in the back.
drag racer
10-4........ going to the dealer in a few minutes to see my guy and get some copies made of the diagrams. thanks
drag racer
lookie.... ok i have a diagram and is the wire i'm looking for the wire labeled LGN/V it is DATA BUS on the cluster end and SERIAL DATA LINK on the ECM end also it goes to DATA LINK CONNECTOR it is pin #3 on that end . i have a digital tach/shift light i'm installing.
Not sure what your digital tach requires but the LGN/V wire (serial data) probably won't work. The ECM pin #3 (marked as not used in most schematics) is the Tach signal wire. You would also need a 72076-00 socket terminal for the ECM connector since this pin position is empty as shipped from the factory. Some people tap the control signal to the coils on pin C of the coil connector (blue with orange stripe or yellow with blue stripe) but I think the tach signal provided by the ECM is better.
Friend of Max.
:stupid:
I think there are a few threads on how to wire up a shift light.
drag racer
#3 pin not empty!!! i've got the pass seat off and the ECM is unpluged pin #3 is a light green/violet wire and pin #4 is empty now what?
Sorry, I don't have the '06 wiring diagrams. They must have changed things.
From 2002 to 2005 that LGN/V was the serial data line and went to pin #5. If it's in #3 now you'll need to get help from someone with the newer drawings.
The drawing I have that shows the tach output on pin #3 is drawing number v0063x8x labeled "Figure 1-4. Starting Circuit" on page 1-11 in the 2002 VRSCA Electrical Diagnostic Manual.
drag racer
the diagram i have says the #3 pin is unused also. i must have a old diagram dammit, whos got newer diagrams. UPDATE i'm an idiot, i was looking at the wrong module we will git it fixed monday i'm leaving for myrtle beach in the morning. thanks for all the help folks ya'll are great
drag racer
it's alive..... it's alive.......... tach works great pin #3 was the trick thanks to all, especially rjrivero thanks agin.
1 - 10 of 10 Posts
