Hi, I still have problems with my vrscr. When I stop at traffic lights etc the bike stalls, starts right up then stalls again when coming to a stop.
I have cleaned the iac.
I have changed the vss.
I have flashed a new map with screaming eagle super tune, I felt this made the bike smoother and more responsive.
I put a new battery on.
I have now gone back to the original map.
My indicators don't cancel and my speedo has stopped working.
My main issue is the stalling.......
Any help is greatly appreciated.
Today i spent most of the day
I have disconnected the grounds, cleaned, copper greased and retightened.
Removed, tested and cleaned the battery.
Re-cleaned iac.
Disconnected ecm, checked cables refitted.
Disconnected all electrical connections, checked and refitted.
Checked voltage regulator.
Disconnected the speedo.... Reapplied.
Put it all back together.
Warmed the bike up. Then cleared codes.
Took bike for test ride and it stalled 90% at junctions etc. Rechecked codes and I've got u1255.
The vss has been changed with a genuine HD part.
I'm still frustrated by the stalling.
Anything else i can try Thank you in advance
NickJ
Re-cleaned iac.
NickJ
