1 - 7 of 7 Posts
Anyone know of the stock dragbar's part #? I need to order one asap. Get it shipped this week. :p
-I want to order it online and not have to talk to a dealer.
For the 06 Street Rod it's #55997-06. I don't have the 07 book.
In the Shark Tank!!!
07 R bar is 1" wide and slight more pull back....
Discussion Starter #5
No issues with the brake lines when swapping from an o6 to the 07 R bars? I'd like a little more pull back.
This might be to much to ask but could I also get the part number for the switches and switch housing on the clutch side of the bars? How about a clutch lever part number. If you give me part numbers I'll give you pics of my busted R after I laid her down good. :(
I switched to 07 front brake hose at same time I switched to the 07 bars. The 06 clutch hose was long enough and then I found the Screaming Eagle clutch hose and that worked with the 07 bars.
No more broken R stories...
Live Free Or Die
I've got '06 bars, brake and clutch hoses, and throttle and idle cables that I would be willing to sell. Send me a PM if you are interested.
1 - 7 of 7 Posts
