Unless you're young and like riding around bent over on the bars all the time I wouldn't recommend stock R bars. I replaced mine with black '07 R bars and front brake hose which are a bit higher and really liked it, then got older and replaced them with black late model DX bars which are higher yet. Did not use the DX riser I used the stock R bar clamps, DX bar bend clears R clamshell - the clutch flex hose is long enough but you'll need a DX front brake hose P/N 41800134 for those DX bars to rotate aft, and a little wire rerouting but it all works very well, much more comfortable and still low enough for that racer R look. Used parts are out there as well but new bars are best, not bent. New bars & a brake hose are not cheap like $ 260 so check the salvage yards - you might luck out - also any 1" bars with a similar bend like sportster bars may fit with no need for a front brake hose - just ask a few dealers what they might have as take-offs
