2002 VRSCA
26000mi
Original Fuel Tank
Fuel gage wasn't working so decided to troubleshoot this afternoon.
First I checked the schematics.
It looks like a variable resistor setup to divide voltage down to generate a signal that feeds back to the computer to indicate level.
I checked voltage on the connector... High = ok Lo = ground (ok) Signal = 0V
This says to me that there is a malfunction in the sensor or an open.
I pulled the assembly from the tank... The float appears to function correctly...but still no signal on the connector.
After further probing, I found that there was a small portion of the resistor strip side of the sending unit that flaked off just below the connector causing an open.
As a cheap *******, I attempted to repair by soldering a bridge (this is above the area where the float tops out) but could not get the solder to take. I don't see a straight forward way to effect a worthy repair and I'm not interested in a flaky repair that could result in a spark within the fuel tank. It looks like I'll be calling my friends at the dealer to order a new sending unit this week.
75122-01 Sending Unit
Looks like it'll be a busy week....I ordered new brake pads this morning.
26000mi
Original Fuel Tank
