1 - 11 of 11 Posts
  1. can anyone help , the alarm is driving me up the wall , i want to pull the plug on it for good , has anyone taken the fuse out ? If so is there a specific way or just remove it , cheers tonyo,
On the non US models you are stuck with it. On the US models you can disable autoarm. The only way I could see to do it would be to change the TSSM for a US spec one then have the HD dealer program the ECM to US spec with Digital Technician. (if they would do it, and a big if!)
If it is just the noise that bothers you, you could remove the siren / battery pack. to shut it up but the immobiliser etc would still kick in.
Ide be more than happy to disarm the syren ,
Ide be more than happy to disarm the siren , where would i find this battery pack . Cheers,
Could you just replace the TSSM with a TSM eliminating the security system all together?
That is another option if you didnt want to use the security ever again. The only thing I am not 100% sure about is if you change the TSSM for any other than the original I think it has to be programmed by DigitalTechnician so you have the same problem as changing it for a US version. As I say not certain.
The siren and battery is in one piece and is under the frame just behind the petrol tank. An easier option could be to snip the Light Green / Brown wire on Pin 11 of the TSSM plug. This is the signal wire to the siren.
According to my documentation the security module and the siren are two different modules.
Security system can be 68200-07 68207-07 69271-07 or 69722-07 depending on your bike. They fit all VRSC models, 2002+ touring, 2003+ softtails and 2004+ Dytna's
The siren kit is 68328-02 which should be good for all 2002-2007+ bikes.
It should be noted these numbers are taken from the H-D instructions for the kits at the time I purchased them. I am not sure of the fitment of future models.
There is a module under the passenger seat cushion. It has a short wire sticking out of it which is the alarm antenna. Simply unplug this module.
Depends on his year. If its pre 07 which I am guessing it is as he posted in the vrsca section then those modules did not have an antenna.
1 - 11 of 11 Posts
