1 - 3 of 3 Posts
I got a noise in back wheel of my dx.usually it makes this noise after riding it a bit . im guessing that something is heating up.also i think i picked up a slight vibration at around 50mph and somtimes when coming to stop i feel slight vibe. Harley checked berings and brakes says okHas anybody had any similar problems ?
Some have had problems with the rear wheel bearings. There is also the cush drive in the rear. It's a rubber hub that connects the sprocket to the wheel and sometimes a little silicone or grease will quite it down or your drive belt may be too tight. Good luck.
John
How many miles do you have on the bike?
My 06SE made a squeal from the rear (could hear it at certain speeds). I mentioned it to the service guy at the 1000 mile service check and they realigned/re-tightened the back wheel/belt and no issue since then.
Sometimes the dealer performed 1000 mile service can be worth the price (also had them check the front end/steering to cure the wobble issue above XYZ speeds).
1 - 3 of 3 Posts
