APPLICATIONS
Techron® Powersports & Small Engine keeps the entire fuel system clean with every fill-up. Techron Powersports & Small Engine is designed for gasoline carbureted or fuel injected spark ignited engines. For best results before a long period of no use or seasonal storage, add Techron Powersports & Small Engine as directed and top off the tank to 7/8 full to allow for any expansion.
Treat rate: • 1 oz. of Techron Powersports & Small Engine treates 4 gallons of gasoline • One 10 oz. bottle of Techron Powersports & Small Engine treats 40 gallons of fuel
Recommended for use in: • Gasoline engines, including carbureted, two-stroke, four stroke, port or electronic fuel injected and direct injected engines. Not for aviation
Techron® Concentrate Plus, Complete Fuel System Cleaner, is designed for gasoline carbureted or fuel injected spark ignition engines. To keep the entire fuel system clean, use Techron Concentrate Plus, Complete Fuel System Cleaner, every 3,000 miles (4,800 km) or at scheduled oil change intervals, not to exceed twice per oil change. Recommended for use in: • Spark ignition engines with gasoline, ethanol and gasoline/ethanol blends • Direct injected gasoline engines (DISI) • Gasoline hybrid vehicles Suitable for use in: • Gasoline two-stroke air-cooled engines (motorcycle or chainsaw) • Gasoline two-stroke water-cooled engines (motorcycle or marine) • Gasoline four-stroke lawnmower, motorcycle and marine engines
Techron Fuel Injector Cleaner is designed for all carbureted or fuel injected spark ignition engines. Safe to use every 1,000 miles or as needed to keep fuel injectors clean. Suitable for use in two-stroke engines. Will not harm catalytic converters and oxygen sensors. Not recommended for diesel engines
Ratio depends on which you are using and is listed on bottle..................
