1 - 3 of 3 Posts
So, I just purchased a pcIII with a custom map for a vmodded exhaust. I was wondering if there's a how to on this. I saw one in the how to section, but it was the exhaust with the slight turn downs. I imagine its pretty much the same. Any tips on the best/easiest way to vmod my exhaust.
p.s. my exhaust is already drilled. Thanks!
Try this post with links to others that I have used in the past.
http://www.1130cc.com/forums/showpost.php?p=1652110&postcount=4
Thanks nykbob! Quick question: with the R exhaust, you dont have to drill from the front? Just from the back, and the Baffles pull right out? Second: I drilled my exhaust already with the 8 holes, and the holes are pretty close to the outside of the exhaust, so is it possible to drill with a bigger holesaw? will this affect the vmodding at all? Thanks!
1 - 3 of 3 Posts
