To boost or not??
So out of all my precaution to keep bolts straight and and not come up with the misc bolts that you dont know where they go...:banghead: I have three of these misc bolts, they are 5mm and like 7/8 of an inch long including the head...now the reason I think these are for the velocity stack is I can't find my Baggie for them. :spank: but I can't find the other three. So does these sound right for the velocity stacks?
Yes. Look in the lower airbox, or in the stacks. I seem to always have "extra" hardware! THen go buy new, and promptly find the missing parts! Joe
Super Moderator
....I have three of these misc bolts, they are 5mm and like 7/8 of an inch long including the head...
... So does these sound right for the velocity stacks?
Yes except that these are 6 mm screws not 5 mm. 5 mm is the size of allen wrench that's used to remove or install these.
To boost or not??
Discussion Starter #4
Thanks for the correction this is what I meant! :bash: I will try and find the missing three otherwise I'll hit up the dealer and see if they have any in stock..
141hp/91 Ft lbs tq!!
Stripped velocety stack bolt
Do I need to tap the hole and go with a bigger fastener? It's running topless under a k&n filter with both stacks removed so the bored out throttle bodies have no resistance breathing whatsoever.
Super Moderator
....It's running topless under a k&n filter with both stacks removed so the bored out throttle bodies have no resistance breathing whatsoever.
This is a bad idea.
The fuel requirements will be dramatically changed from what an engine with velocity stacks requires. The velocity stacks are an integral part of the "tuned intake" system. Running without stacks shortens the intake tract and moves the resonant frequency to higher RPMs, however, if the ECM isn't reprogrammed to compensate for this the engine could run very rich in the normal resonant RPM range and very lean in the high RPM range.
