james
i maybe in need of a shifting fork and i search but no answers to my question... is the vnh shifting shaft and fork better or worse than the stock ones??? i seen some one say back in 2008 it may wear out the shifting drum... no results in what happened... how many shifting forks are there???
Super Moderator
I've never heard of a V&H shift fork.
The VRSC bikes have three shift forks:
1st/3rd (35428-01K),
2nd (35429-01K),
4th/5th (35430-01KA, improved in 2005).
V&H has a shift shaft (35-0055), 2nd gear set for VRSC (35-9006), and 2nd gear set for VRXSE (destroyer, 35-9001).
Super Moderator
Haven't used them myself, but yes they do exist. ...
Looks like a 2nd gear shift fork from the pictures but it doesn't actually specify which one it is. I suppose the solid pin is better for drag racing but I haven't heard of problems with the OEM forks in street use except the pre 2005 4th/5th fork.
AIM Bagger Edition
That shift fork and the 2nd gear upgrade, ( which lessens the gap between 1st and 2nd gear ) are more for race applications, although V&H does in fact sell a street bike application for the 2nd gear upgrade. I'm currently running it in the 1430cc motor that they built me for my V-Rod Bagger.
That being said they didn't want to install it when I had the motor built. They felt it wasn't required.
james
Discussion Starter #6
i priced the stock shift drum kit and all three shift forks and shifting shaft for just over 500.00 hopefully when i open it up i don't run into a bunch of busted gears. i didn't find any metal in the oil or the magnetic plug so i m hopeing that is a good sign...
